1141Views10Replies
can i built a powerfull flipper (on robot) using 100rpm motor?
want to build a robot which has power to lift or throught the opponents 5kg (min) battle bot way from the arena... or away from me
3 years ago
Can you just have a motor to move the flipper?
7 years ago
no way. u need a lot more powerful motor
10 years ago
no absoloutley not your household fan motor which is dc runs at about 3000 rpm so to get something like that to move id recommend at least a good motor at the source you could probabaly get one for about 10$
11 years ago
You'd want a gas-powered ram I think, not a motor (too slow for a "flip")
L
Answer 11 years ago
I suppose theoretically you could use the motor to pressurize a air tank to run the ram.... It would be really slow to repressurize after the first shot, though.
Answer 11 years ago
Fire-extinguisher ('dioxide) and an air-ram/piston, that's the way to "flip"-weight in these circumstances.
L
Answer 11 years ago
Definitely a better idea. I was just trying to use the motor for something other than ballast.
11 years ago
To use the 100 rpm motor mount a cam on the motor so that as it turns it flips up a lever that you have run under your opponent. Every 2/3 second the lever will flip up so it will need a spring to pull it back down again.
11 years ago
A big solenoid would do it and not require time to refill the tank. I t will have a draw on the batteries though.
11 years ago
You could use the motor to wind down a spring, then release the spring with a catch activated by a solenoid.
