1734Views2Replies
Author Options:
can i charge 6 volt battery with 12 v 4 amp power supply? Answered
Hello every one can i charge my 6 v lead acid battery with 12 volt 4 amp powersupply
once i did it burn my supply  why?
Tags:battery
jbaker22
jbaker22
8 years ago
That means it has low resistance, or you had a short curcuit that it burned up. Your battery may not be good anymore and needs to be desulfated, which I can show you. Here is cheap charger to replace the one you mentioned.
http://www.facebrake.com/products/NOCO-Genius-G750-6V%7B47%7D12V-750mA-Fully-Automatic-Battery-Charger-and-Maintainer-(Grey)-%252d%252d-4D3B9O004YK3NF698.html
rickharris
rickharris
8 years ago
Not a really good idea. You need to limit/control the current flowing - The voltage should be around 8 volts to charge a 6 volt battery
