90Views5Replies
Author Options:
can i control motors through a dvd reader pcb? Answered
i am making something (it is for a contest so i cannot tell you what it is) it is kind of like this https://www.instructables.com/id/Poor-Mans-3D-Printer/    though i am using arduino uno
to control the motors out of the dvd drive can i use the pcb that was in the dvd drive
(it has 40 pins)
iceng
iceng
Best Answer 6 years ago
As every one said, Sadly No, you cannot, unless you had the 44 pin version :-)
That Poor-Mans-3D-Printer uses several stackable Motor Driver Shields L293D
to drive the motors as should you.
That 40 pin IC you like, is made to track a DVD and NOT move an axis motion.
Downunder35m
Downunder35m
6 years ago
You can't, the connector you mean is the IDE connection and won't help you.
But any stepper motor driver / shield should do after you worked the stepping out.
bravoechonovember1
bravoechonovember1
Answer 6 years ago
ok thanks
would any other dvd reader work?
steveastrouk
steveastrouk
Answer 6 years ago
No. Same reason.
Wired_Mist
Wired_Mist
6 years ago
If your only using the Drives for motion (and not as a DVD player or something) I would Directly interface with the motors themselves. Looks like thats how the author of the I'ble you posted used.
You may be able to hack into it. The IDE cable only needs 16 pins to control it, the rest are all power connections and grounds. leaving you with all of 4 extra pins on the Uno. Wich doesn't sound Promising !
