4464Views4Replies
Author Options:
can i fix a cup with epoxy or rubber cement and still be able to drink out of it without getting poisoned? Answered
i want to fix a glass but i dont know if i can still use it. yes, i know i can buy another one but lets just say its a cup i need to fix.
jeff-o
jeff-o
Best Answer 11 years ago
Epoxy is your best bet.  If you can, find one that is meant specifically for glass (is it glass, plastic or ceramic?)
After it's repaired, I wouldn't recommend using it for boiling hot liquids or putting it in the freezer.
wetnap
wetnap
7 years ago
No, it has to be food grade adhesive, even epoxy has to be or else there is leeching risk.
lemonie
lemonie
11 years ago
I have used cups mended with epoxy. Once the resin has set it is pretty inert & harmless.
L
Burf
Burf
11 years ago
Rubber cement, no. Epoxy probably, if you let it cure completely and don't subject it to heat above the temperature of a cup of hot coffee. Be sure though, and read the label to insure it doesn't contain any toxic compounds.
