I am already testing electric single lifting mini helicopter,traial process and measure ment is better than the last month.Range 50 km Top Speed: 40 km/h Weight: 50 kg, max load 75kg Motor: Rear wheel hub motor Wattage: 500W Batteries: Sealed Lead Acid, 48V 24AH Calculation ok but engine is Best option.
Small helicopters need 1HP to lift every 10 Lbs at sea level on Earth. You have to add the Structure wight 485 Lbs Your own body weight 110 Lbs The motor weight ___ Lbs. You will need to develop 48 to 60 HP And the battery weight ___ Lbs. Hope you click best answer. You might be interested to learn, a pound of battery might get you 100 watts, and a pound of gasoline will get you 1300 watts ...................... A
Then what is the technical s for this copter. also can u share the average speed, highest at a stretch flying time, total weight, type of engine, safety etc.
Sorry guy, I was making the case that you CAN NOT hang out under an electric prop. Did you even try to Google a 50HP electric motor weight like the kind of advanced design the Tesla electric car is using and work the formulas ?
this 2-stroke gasoline engine for two main rotor of opposite directions ?? or one 2-stroke for main and one two stroke for tail rotor ?? can u recommend any good video or technical article to make a one man helicopter ??
2-stroke gasoline engines give you far more power-for-weight, you'll not get very far at all trying to use electric motors. Also, you'll struggle to control these things should you get one off the ground.
2 years ago
Top Speed: 40 km/h
Wattage: 500W
Reply 2 years ago
And what is your new point ?
2 years ago
And your point being ?
9 years ago
Answer 5 years ago
hi,
Answer 5 years ago
5 years ago
hi lemonie,
9 years ago
L
9 years ago
your local microlite/air craft club will be able to tell you much much more and safer, too!
9 years ago
Not legally, not safely, probably not at all given the weight of batteries but that's a guess.
