84Views7Replies
Author Options:
can i increase 200a to 5a? Answered
plz help me,, i have a 12v 200ma dc adapter and i need to transform it into 12v 5a dc adapter.is it possible? i
Tags:ampere
Josehf Murchison
Josehf Murchison
5 years ago
If you want to use the adapter as a trickle charger and charge a 12 volt battery, then power what you want to power with the battery.
You can do it, otherwise you need a bigger adapter.
iceng
iceng
Answer 5 years ago
+1
As said, charge for 47 hrs at 200 ma and then discharge at 5A for 1 hour.
gizmologist
gizmologist
5 years ago
The formula for power is Volts times Amps. Your adapter is 12V X .200 = 2.4 Watts power. The adapter you want is 12V X 5A = 60 Watts power. You cannot increase the power (Wattage) of an adapter. If you increase the current, you will decrease the voltage and vice-versa.
seandogue
seandogue
5 years ago
No. it is not possible. You'll have to purchase or fabricate a higher out dc adapter
Downunder35m
Downunder35m
5 years ago
That is 40 times over the rated output of the adapter -I would not even bother to try.
If you need just 12V fixed use a PC power supply or an old style battery charger with rectifier and voltage regulator added.
iceng
iceng
5 years ago
No, not continuously possible.
But can for an hour every other day.
