2935Views12Replies
Author Options:
can i make a mini electric welder out of a disposable camera? Answered
only for small joints not to be used, just as an experiment
lemonie
lemonie
Best Answer 11 years ago
Welders need high current more than high voltage. A 12V car battery will happily weld stuff. These things are dangerous with e.g. metal watch-straps, screwdrivers etc.
Otherwise a heavy high-amerage power-supply (not mains, that's asking for trouble)
L
sharlston
sharlston
Answer 11 years ago
how about drill batterys?
stephenniall
stephenniall
Answer 11 years ago
You can But not very good .
I learnt this when  i was using a piece of pencil lead for an experiment and i welded a piece of wire to the battery !
lemonie
lemonie
Answer 11 years ago
You might weld small stuff, but would risk damaging the batteries. If you're thinking about full size electric welders think around 50-100 amps (though what they actually use varies).
L
Molten Boron
Molten Boron
Answer 11 years ago
That raises an interesting point. Could you conceivably convert the high-voltage low-amperage (watts = watts) into high-amperage low-voltage?<br />
lemonie
lemonie
Answer 11 years ago
This is what electric welders do. Input up to 13A @ 240V, output maybe 100A, at maybe 30V (all rough). A big heavy transformer is the largest part of these devices.
L
Molten Boron
Molten Boron
Answer 11 years ago
Badda-boom! Transformer-driven capacitor welding!
nepheron
nepheron
11 years ago
I made one with a capacitor from a camera. I wired the capacitor up to a 12v wall adapter and wired the capacitor to two alligator clips. The wall adapter goes through a momentary switch before it charges the capacitor. This keeps the capacitor from over heating/ over charging.
It will "weld" constantly with hair-thin wire attached to one (the negative) alligator clip. The other clip attaches to whatever metal i weld on.
It works so-so for practical uses, but it makes the greatest toy ever!
jtobako
jtobako
11 years ago
It might weld foil, or just burn holes in it.  Not much more.
jtobako
jtobako
Answer 11 years ago
Not really.  The upgraded version sounds better, but the caps get expensive.  Most of the problem here is that the camera circuit is backwards-but I'm assuming anything that can blister my skin has a good chance of spot welding foil : )
orksecurity
orksecurity
11 years ago
Very mini. If you want to weld the foil from bubblegum wrappers, maybe.
steveastrouk
steveastrouk
11 years ago
You can use capacitor discharge to weld things, if the capacitors have a low enough internal resistance, because you can deliver a hell of a lot of current very fast. They ARE dangerous when they are run at high voltages.
