428Views5Replies
Author Options:
can i make the rubiks cube costume in two weeks or less? Answered
Is It possible to make a Rubiks Cube costume in two weeks or less?
Tags:cube
starshipminivan
starshipminivan
11 years ago
Absolutely, as long as you don't actually use it. I've used boxes for several costumes over the years. I'd get (or build) a big square box only slightly longer on a side than the width of your torso. One side must be open, so fold the flaps in. Fold the flaps rather than cutting them off as this helps keep the box square and sturdy. Cut a head hole on the side opposite the opening and arm holes in corresponding sides. To give the look that it is a cube being turned, I'd "turn" the middle horizonal row. Make some corners from scrap cardboard and secure to the centers of the horizontal row of the box. Cut out the existing corner pieces on that row. Then use strips of carboard to bridge the gaps between the turned corners and paint! 2 days, tops!
starshipminivan
starshipminivan
Answer 11 years ago
Oops! I mean, don't use it like the toy. Obviously you'll use it as a costume.
frollard
frollard
11 years ago
You should be able to make it in a day or less!
orksecurity
orksecurity
11 years ago
Depends on how you design the costume. A simple painted box? Probably. A cube with a partly rotated section? Not too much harder; it's two or three stacked boxes rather than one box. A costume with sections that can actually move? I wouldn't try...
