99Views3Replies
Author Options:
can i power a coil gun with 11.1 v with 4400mah with a c rating of 50? Answered
i have 2 x 11.1. volts 2200mAh in parallel which gives me double the current but the same voltage.
will this power a multi staged coil gun?
iceng
iceng
5 years ago
Yes you did, this is a teaching forum helping others to learn.
But your the engineer type who needs answers. So;
1] You are welcome.
2]
LM324 quad comparators are fine, optical detectors are your speed
limiting components ( they are slow with differing turn-on and turn-off
times ) even though the light interrupt is instantaneous the
semiconductor is not.
3] The 18 gauge wire will fuse ( turn red
and pop ) at 82A and thermal resistance begins to be a factor after 5A.
So if your turns are low enough there will be a race between who will
explode first the wire or the Lipo !
4] C battery rating doubles
in parallel and stays the same in series.because current delivery adds
in parallel but stays the same in series. The MOSFET has a forward drop
say a volt at full draw that is 10% of your supply while a capacitor
charged to 200v it is o.5% of the supply.
5] Efficiency in a coil slugger is a function of magnetic flux-coupling and way beyond this text box.
6] Time of 2/3 rise to peak = L / R You need to be study and understand this
http://www.physics.sjsu.edu/becker/physics51/induc...
see picture
7] Coil shape, Flux and Circuitry all affect turn off time thats where experimentation trial and improvement occur.
8]
We learn when things blowup. A fuse should protect the weakest
component. Fusing current on your thin wire is 82A use a fast blow fuse
for the coil. Then fuse your lipo in accordance with the C burst = Short time discharge, value using a regular time fuse.
A
iceng
iceng
5 years ago
You didn't like my last answer true to you.
Energy increases as the square of the voltage !
You would do better with 22.2 volts.
BUT THE TIMING ( Turn_Power_off) WHEN SLUG GETS HALF WAY INTO COIL !
Other wise coil will pull slug Back !!!
I would ask for you to mark the best answer but clearly you didn't believe the EE.
iceng
iceng
Answer 5 years ago
You did click on the neat visual ?
iceng
iceng
5 years ago
When I was your age, we wound 60 turns of 14 gauge on an 18" long tube.
Then using a 2" long single strand of extension wire as a blow up timing fuse, we could put a ball bearing into Sheetrock from across a room, if you anchor the tube. Expect some trial and error, but you have a near endless supply of fuses.
Safety glasses are a good idea and don't stand in front....
Again it is voltage squared that coils a gun not low volt lipos.
The monograph calculator is provided for a nice obsessive guy who wants to inductively work a slug off a table.
