2557Views9Replies
Author Options:
can i turn a fridge freezer in to just a freezer? Answered
i have and old vertical fridge freezer.( freezer compartment on top).  the seals have pretty much gone on the fridge part, so i am wondering if its possible to completely disable the cooling of the fridge part, while the freezer carries on working.
i am assuming also that this will reduce the running cost of the unit if only the freezer5
cheers will
caarntedd
caarntedd
10 years ago
Why can't you just turn the thermostat control in the fridge compartment off?
agatornz
agatornz
Answer 10 years ago
well why didnt i think of that!
caarntedd
caarntedd
Answer 10 years ago
Is that sarcasm, or will it work?
lemonie
lemonie
Answer 10 years ago
Same plumbing, the thermostat being off would shut the whole unit down.
L
aeray
aeray
10 years ago
If you just rip out all of the plastic bits that divide the freezer from the fridge (if it is a sub-compartment-within-the-fridge-type-freezer) or just hack a hole from the freezer compartment to the fridge compartment (if it is a two-separate-doors-with-a-partition-in-between-type) you can have a huge freezer, not a fridge, for free. Your power bill will go up, but not much, as people tend to get into fridges (and hem and haw as they leave the door open) much more than they get into freezers.
agatornz
agatornz
Answer 10 years ago
well only need a small freezer compartment.. and dont need any increase in power consumption lol - part of the reason i replaced the fridge
aeray
aeray
Answer 10 years ago
It appears that I misunderstood your goals. Caarntedd has the right idea- I'd also tape up/block off the vent between the two.
lemonie
lemonie
10 years ago
Why not just seal the fridge-up with e.g. silicone.
Actually taking the fridge plumbing out would be a job for a professional.
L
agatornz
agatornz
Answer 10 years ago
yes have considered that with a pull closed latch.. dont really want to muck with the plumbing..
