2384Views9Replies
Author Options:
can i use 500 watt juicer and mixer motor for electric bicycle? Answered
on motor specification it is written 500 watt , 50 hz ac motor , but when i plug it in 12 volt dc battery it runs slowly it can stop it with hand but i hope in higher dc volt it will run enough to use in my electric bicyle. it is philips juicer and mixer and grinder purchased from india
Tags:ebike
kaustubhhere
kaustubhhere
6 months ago
yes , you can
if you do it just send me pics also
Maliha1238
Maliha1238
7 months ago
Can you help me make a electric bike out for a Kmart mixer
JessicaS325
JessicaS325
3 years ago
connect both field winding and armature winding in parallel. you can get 3000 rpm
rahuldinesh27
rahuldinesh27
6 years ago
Since the motor is rated at 230V, I suggest to use a UPS/inverter to convert battery voltage of 12V to 230V. As anyways battery charger is required for your Electric vehicle.
mpilchfamily
mpilchfamily
6 years ago
Nope the motor will not suppor the load even if it's plugged into the AC outlet.
Suraj Basnet
Suraj Basnet
Answer 6 years ago
thanks for answer
rickharris
rickharris
6 years ago
No - It is intended to run on mains power - i.e.120 or 240 volts. It runs on a battery because it is a universal motor and will operate on DC and AC - Less voltage will mean much less than 500 watts.
This is why higher voltage motors can be a higher wattage whilst being quite small in physical size. a DC 12 volt 500 watt motor would be rather large Approaching the size of a waste paper bin.
