306Views9Replies
can i use a wireless router like a regular router without broadcasting the signal out?
i want to use the linksys 2.4 GHz wireless G router with a 4 port switch. I want to connect three computers to it and not wireless. If not , is there a way to limit the range of the wireless signal to the confines of my home?
Best Answer 11 years ago
Sure. Log into your router. (Usually just go to http://192.186.1.1 ) Then go to the "Wireless" tab.
There you'll see an item called "Wireless Network Mode". Click on that and select "Disabled".
Click "Save" on the bottom of the screen and you're done!
11 years ago
If you need a manual for your router you can go to the manufacturere's webpage - every router I've ever had has had a manual online.
11 years ago
Thanks everyone for all the help and great resources that you have shared, should have it all up and running ( and secure ) in a few days. To every one that replied, Thanks again..V66
11 years ago
You can keep the wireless if you wish and choose from the menu not to BROADCAST your signal - only you will know your signal and password for wireless - anyone else will not see it on their pc's/laptops.
It is in fact what I do.And every router I have ever had (about 7) have all had the same BROADCAST feature.
Answer 11 years ago
It should be noted that this is not a very good security measure since a wireless hub does still broadcast its presence and it's trivial to detect networks that are 'hidden' in this way. (read more here.)
If you want to secure your wireless network you should use WPA encryption with long unguessable passwords and filter connections by MAC address. Here is a decent article on properly securing your home network:
Answer 11 years ago
Ookseer, I understand the question was generic at best, but the security concern ( and links to read ) were a great help. Thank you for the help and the reply..
Answer 11 years ago
I'm sorry - I thought that the WPA(2) security was a given - all I suggested was to turn its broadcast feature off, not to turn security off! Turning the broadcast feature does not disable the security and so extending my answer to security was not appropriate in this case; although your comments on security are spot-on! ;-)
Answer 11 years ago
Agreed
Answer 11 years ago
Thanks for the reply, got router second hand with no manuals or guides. Haven't even tried to use it yet, just trying to get ideas on how to make it work correctly.
