109Views10Replies
Author Options:
can somebody tell me the scientific reason behind that? Answered
i saw  when i wrote with onion juice on a paper, it could not be seen.but after a while, when i put a slight heat on the paper or ironed it, i could see a faint  appearance of the letters i wrote.how did it happen?
rickharris
rickharris
Best Answer 9 years ago
Yes a water mark is put in the paper when it is made - for hand made paper it is woven into the wire grid the paper is formed on. It slightly reduces the density of the paper fibres at that point and results in a visible pattern when viewed against the light.
As far as I recall the wet writing method is not visible when held up to the light so remains secret until the paper is wet again.
orksecurity
orksecurity
Answer 9 years ago
Rick: I believe the wet writing method *is* visible when lit from behind. Easy enough to test, of course. Might or might not depend on the paper in question, though I'd be a bit surprised.
rickharris
rickharris
Answer 9 years ago
Ok have tried this wet writing - Not a water mark - when dry writing is invisible but shows dark when wet. isn't science wonderful :-)
orksecurity
orksecurity
Answer 9 years ago
Surprising, and interesting. Hmmm. Need to figure out why.
rickharris
rickharris
Answer 9 years ago
I will give it a try and get back - Long time since I did it.
rickharris
rickharris
9 years ago
Same with milk
Same with sugar dissolved in water
Cobalt chloride is soluble in water and when wet turns blue but is a pale pink when dry
Wet a bit of paper - Put a dry sheet over the top Write message. Allow bottom sheet to dry. Write anything you like on it. message appears when you re wet the paper.
orksecurity
orksecurity
Answer 9 years ago
BTW, that last is a watermark.
If you websearch "secret writing" and/or "invisible ink" I'm sure you'll find a few thousand more.
Burf
Burf
9 years ago
The heat carbonizes some of the organic esters and sugar making their traces visible.
Re-design
Re-design
Answer 9 years ago
I wish I could talk like that!
