If you are trying to connect two phones to a single USB port on a computer then this is only possible with the use of a USB Hub.
If you want to connect two phones to a single USB port for the purposes of charging, then this is possible (in theory), but how well it works will depend on how much current the USB port can supply. Most typical USB ports and hubs (even active-powered ones) don't supply enough current to charge a single phone as quickly as a mains power adapter, let alone two phones.
Looks like not to much interest in your question. It is a little vague.
From my understanding of it, you are asking if you can connect one phone to another directly with a cable. The answer to that would be no. You need a go between like a computer. You could connect 2 phones to the same computer and use that computer to transfer data from one to the other but the phones cannpt connect with out an interface.
If you are asking about charging phones, it is possible but it may take a very long time to charge both. Buy a dedicated smart charger or USB charging hub.
4 years ago
4 years ago
4 years ago
