3769Views5Replies
Author Options:
can we send analog signal using bluetooth without converting to digital signal? Answered
i wanted to attach bluetooth to lvdt sensor.  output of that lvdt is sine wave . that signal is given to bluetooth , is it possible to send sine wave using bluetooth without converting into digital form?
steveastrouk
steveastrouk
9 years ago
If its an LVDT, I'd get a DC signal out of a demodulator, and then pass it to some kind of BT interface. The information in the AC signal is both phase and amplitude, which you won't be able to preserve in the conversion process otherwise.
By far the simplest thing to do it to simply use an ADC, and stuff it out through an SP profile on BT.
seandogue
seandogue
9 years ago
Nope, you'll need to convert the signal prior to feeding it into the bluetooth stream
Inn fact, you'd want to strip off the sine carrier prior to conversion, afaik.
steveastrouk
steveastrouk
9 years ago
I suspect its possible with the headset profile, and the right equipment.
Steve
lemonie
lemonie
9 years ago
No, Bluetooth is a digital format, the hardware is digital.
L
iceng
iceng
9 years ago
No, but you can check this link yourself.
Section 32.4.5 RFCOMM Protocol  talks about
similarities to RS232 serial communications.
A
