158369Views31Replies
Author Options:
can you give me cool cmd tricks? Answered
give me cool cmd tricks and your email and I send you $50
Tags:help
tarzanvigelandos
tarzanvigelandos
1 year ago
i know are not gonna see this reply but im gonna do it to my dad until he stop putting internet block on the wifi
hookian
hookian
8 years ago
to get cmd in school
1) open notepad
2) type
@echo off
command
comand.com
pause
3) save as cmd.bat
4) click it and you have cmd
EricJ156
EricJ156
2 years ago
Background
0-black
1-blue
2-green
3-aqua
4-red
5-purple
6-yellow
7-white
8-gray
Foreground
9-light blue
a-light green
b-light aqua
c-light red
d-light purple
e-light yellow
f-bright white
Hebron12
Hebron12
2 years ago
type echo on then click enter then type shutdown -i then click enter then a screen will come so click add and put a nother computers hostname to check a nother computer type hostname and it will show the computers hostname so back to you'res type the other computers hostname then click enter go under and click the thing that says reset and change it to shutdown then at the very bottom it will say comment and click it so type to shutdown and thats it
RyanK198
RyanK198
2 years ago
Go to command prompt on a friends computer and type in "ipconfig/release" they will not be able to get on the internet, make them pay you to fix the problem. fix it by typing "ipconfig/renew into the cmd.Boom, free money.
WhoDat21
WhoDat21
2 years ago
do
pkgmgr /iu:"TelnetClient"
(you will need admin perm)
then close that cmd
open it up back again
then do
Telnet Towel.blinkenlights.nl
have fun !
FaithQ1
FaithQ1
2 years ago
Why There are only internet network I only connect Too
Why can't they bring up other internet I can get instead of those I connect too before ..
Yardape1
Yardape1
2 years ago
The command “netsh wlan show profile SSID key=clear”, replacing “SSID” with the Wi-Fi name of the network. If you’re not sure about the networks you’ve connected to, use the “netsh wlan show profile” command.
TeamP5
TeamP5
2 years ago
Just bring a usb stick with anything you want on it. Well depends if that works ty
Re-design
Re-design
11 years ago
Do you realize that offering $50 for cool cmd tricks is a legally binding offer and you could be sued for fraud if you don't pay every trick sent in.  You need to be more careful what you say on the internet.
davidc311
davidc311
Answer 3 years ago
Actually, he didn't swear, so it's not a legally binding offer. So maybe you should do your research before you critique others, mate.
KiNG-_-R41N
KiNG-_-R41N
Answer 3 years ago
No, Legally it is a spoken contract meaning he does hae to pay $50, so maybe YOU should do your research davidc311
alfredov27
alfredov27
Answer 2 years ago
actually he said a cool trick so it depends on what he finds cool no research was need just for you to read. knowledge is power!!!!!!
FifthAxiom
FifthAxiom
3 years ago
Especially for you my make me sick script.
@echo off
mode con cols=80 lines=50
color 0a
:feelsicker
<nul set /p =- _ - _
goto feelsicker
Gadget kid
Gadget kid
3 years ago
open cmd as administrator and type :
attrib +s +h D:/folder name
Note: ( D:/ is my disk in my pc you can use yours wat u have in ur pc)
This command helps to hide a folder or file which makes you can't see the folder even though you change the settings to show hidden files or folder
If you want to see the folder which you have hidden just type the command
attrib -s -h D:/foldername
Note: the folder name shouldn't have any space in between
Ch0ocolat3M0ose
Ch0ocolat3M0ose
3 years ago
Type this in to bypass most websites (thats if you have a web blocker)
Example:
tracert www.youtube.com
You will know when its done when it stops. When its done it should say "trace complete" above that it should have a list of words and numbers. The last numbers in parentheses is the IP address of the website you traced. Put those numbers in your web bar and it should bring up the site your looking for.
Pranav Tyagi
Pranav Tyagi
3 years ago
title Cracking Bank Passwords
@echo off
color a
:start
echo %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random%
goto start
NicolasS101
NicolasS101
4 years ago
If you relly want to get cmd in school with windows 10 type this in notepad:
@ECHO off
START %SystemRoot%\system32\cmd.exe
it's the only thing that still works at my school so much success and you're welcome
AdrianT24
AdrianT24
5 years ago
cool tricks that will make any noob think you are a hacker;
1. Tree; this command will map your computer's... Everything, it just makes a bunch of text appear
2. Ping WEBSITE; Website is replaced with any website you want this will give you the website's IP address
3. Help; shows a list of commands
4. Ipconfig; gives info on your computer's IP and Internet stuff
5. Net; it gives information about your network, try "net send*" after the asterisk write a message you would like to broadcast to all computers on your network, type share, file, or start and more info code will appear
7. DDOS; type in ping -n 10000 -l 10000 1.2.3.4 this is just an example ip, not much will happen but if you run it like crazy u will rip the IP
8. Shutdown; self explanatory
siikskill
siikskill
8 years ago
telnet towel.blinkenlights.nl
type that in CMD and you can Watch Star Wars
prao6
prao6
8 years ago
1. Use Ctrl-C to Abort a Command
Just about any command can be stopped in its tracks with the abort command: Ctrl-C.
If you haven't actually executed a command, you can just backspace and erase what you've typed, but if you've already executed it then you can do a Ctrl-C to stop it.
Warning: Ctrl-C isn't a magic wand and it can't undo things that aren't undoable, like a partially complete format command. However, for things like the dir command that seem to go on forever or questions you're asked at the prompt that you don't know the answer to, the abort command is an excellent Command Prompt trick to know.
2. View a Command's Results One Page (or Line) at a Time
Ever run a command, like the dir command, that produces so much information on the screen that it's almost useless? You're not alone.
One way around this is to execute the command in a special way so whatever information is generated is shown to you one page, or one line, at a time.
To do this, just type the command, the dir command for example, and then follow it with the pipe redirection operator and then the more command.
For example, executing dir /s | more will generate the thousands of lines of results that you expect from the dir command, but the more command will pause each page of results with -- More -- at the bottom of the page, indicating that the command is not done running.
Just press the space bar to advance by page or press the Enter key to advance one line at a time.
See Command Prompt Trick #7 below for a different solution to this problem.
3. Run Command Prompt as an Administrator Automatically
Many commands require that you execute them from an elevated Command Prompt in Windows - in other words, execute them from a Command Prompt that's run as an administrator.
You can always right-click on any Command Prompt shortcut and choose Run as administrator but creating a shortcut to do the same thing can be a huge time saver if you're a frequent Command Prompt power user.
To complete this Command Prompt trick, just create a Command Prompt shortcut on the desktop, enter the shortcut's properties and then select the Run as administrator box located in the Advanced button on the Shortcut tab.
4. Become a Command Prompt Power User with Function Keys
The fact that the function keys actually do something in the Command Prompt is maybe one of the best kept secrets about the tool:
F1: Pastes the last executed command (character by character)
F2: Pastes the last executed command (up to the entered character)
F3: Pastes the last executed command
F4: Deletes current prompt text up to the entered character
F5: Pastes recently executed commands (does not cycle)
F6: Pastes ^Z to the prompt
F7: Displays a selectable list of previously executed commands
F8: Pastes recently executed commands (cycles)
F9: Asks for the number of the command from the F7 list to paste
Command Prompt Trick #17 is full of arrow key shortcuts, a few of which are similar to these function key tricks.
5. Hack the Prompt Text
Did you know that the prompt itself in the Command Prompt is completely customizable thanks to the prompt command? It is, and when I say customizable, I mean really customizable.
Instead of C:\>, you can set the prompt to any text you want, have it include the time, the current drive, the Windows version number, you name it.
One useful example is prompt $m$p$g which will show the full path of a mapped drive in the prompt, alongside the drive letter.
You can always execute prompt alone, without options, to return it to its sometimes boring default.
6. Get Help for Any Command
Believe it or not, the help command does not provide help for every Command Prompt command. However, any command can be suffixed with the /? option, usually called the help switch, to display detailed information about the command's syntax and often times even some examples.
I doubt that the help switch is the coolest Command Prompt trick you've ever heard of, but it's hard to disagree that it's one of the more useful.
Unfortunately, neither the help command nor the help switch offer much in the way of explaining how to interpret the syntax. See How To Read Command Syntax if you need help with that.
7. Save a Command's Output to a File
An incredibly useful Command Prompt trick is the use of redirection operators, specifically the > and >> operators.
These little characters let you redirect the output of a command to a file, giving you a saved version of whatever data the command produced in the Command Prompt window.
Let's say you're about to post a computer problem to an online forum, like my computer support forum for example, and you want to provide really accurate information about your computer. An easy way to do that would be to use the systeminfo command with a redirection operator.
For example, you might execute systeminfo > c:\mycomputerinfo.txt to save the information provided by the systeminfo command to a file. You could then attach the file to your forum post.
See How To Redirect Command Output to a File for more examples and a better explanation of how to use redirection operators.
8. View Your Hard Drive's Entire Directory Structure
I think one of the neatest little commands is the tree command. With tree, you can create a kind of map of your computer's directories.
Execute tree from any directory to see the folder structure under that directory.
Tip: With so much information, it's probably a good idea to export the results of the tree command to a file. For example, tree /a > c:\treeresults.txt, just as explained in Command Prompt Trick #7.
9. Customize the Command Prompt Title Bar Text
Tired of that Command Prompt title bar text? No problem, just use the title command to change it to whatever you like.
For example, let's say your name is Maria Smith, and you want to express your ownership of the Command Prompt: execute title Property of Maria Smith and the Command Prompt's title bar will change immediately.
The change won't stick, so the next time you open Command Prompt the title bar will be back to normal.
The title command is usually used to help give a custom appearance in script files and batch files... not that I'm saying titling it with your name isn't a good idea!
10. Copy From the Command Prompt
As you may or may not know, copying from the Command Prompt is not as easy as copying from other programs, which is part of the reason why saving a command's output to a file, Command Prompt Trick #7, is so handy.
But what if you do just want to copy a short section of text to the clipboard? It's not too hard but it's not very intuitive either.
Right-click anywhere in the Command Prompt window and choose Mark. Now, highlight with your left mouse button whatever you'd like to copy. Once your selection is made, press Enter.
COMMAND shell wizard
1. To crash a website, type in:
Ping (website you dont like)
After it pings the website, you will find the ip address of the site after "ping statistics for..."
After that, type in this:
Ping (the website's ip address) -t -l 65500
NOTE: this will only work on some computers.
2. to find the ip address of a computer, type this in:
ipconfig
3. to change a password of a user on the same computer, type in:
net user (username here) *
it will say type in password here. after that, type it in. it will not show up for security. It will then say confirm, and type in the same password.
NOTE: this will only work if you are an administrator
4. to change the title, type this in:
title (whatever you want the title to be)
and after you press enter, it will change the title
5. to change the color to the matrix, type this in:
color 0a
after you press enter, it will be green with a black backround.
6. to find all connections happening on your computer, type this in:
netstat -n
or:
netstat
7. to add a user, type this in:
net user (the username you want) /add
8. to delete a user, type this in:
net user (the username you want deleted) /delete
9. to make it echo something, type this in:
echo (your message here)
10. to clear the cmd, type this in:
cls
11. to shutdown a computer on the same network as you, or your own, type this in:
shutdown -i
NOTE: a page will appear. in the space that says computer name, type in the ip address of the computer you want to shutdown. you can change the settings, but I think you can figure them out.
12. to create a cmd, open notepad, and type this in notepad:
command.com
save it as this exactly: "cmd.bat"
open it and you have cmd.
13. to create the matrix coding, type this into notepad:
@echo off
title matrix
color 0a
:h
goto h
save it as this exactly: "matrix.bat"
NOTE: press Ctrl+c to stop it, and press Alt+Enter to make it full screen.
NOTE NOTE NOTE NOTE: this post is for educational purposes only and is not to be used illegally in any way. If you choose to do so, I am not responsible for any of your actions.
I'm not taking your money
miiwii3
miiwii3
11 years ago
Ok if you are at school and feel evil you can shutdown all computers or just a selective computer my typeing shutdown -s -t  60(time till shutdown) -m \\(computer name/ip to get cmd type cmd in run. search telnet on here and you should find a cool star wars movie in symbols! it mustve taken for ever to make. uhm oh, say a website is blocked on school computers all you have to do is type in command prompt ping (website name) and the first numbers that appear are the ip address. all you do then is put the ip address in the address bar in your browser. uhm if you can get enough computers you can crash a site(i do not take ANY responsibility). to do that search ddos(or dos) attack on youtube.com uhm there is a way to send a message to other computers but i forgot the code. and if you ever forget the shutdown code for cmd just type shutdown and it will better explain it.
My Website miithewii.webs.com check it out.
ill message you my email. if i find more ill message you but if you ever need some remember this AMAZING site it explains everything! HERE
ojones2
ojones2
Answer 9 years ago
hey can you explain this a little better... this is tempting >:D
acidbass
acidbass
Answer 11 years ago
i actually did that yesterday LOL
marlish
marlish
10 years ago
If you want an administrator account and you have a limited one then you cannot do most of the things like downloads and stuff so heres a way to make your limited account to a administrator one. Just open cmd and type the following.
If cmd is blocked at school or wherever the place then open notepad and type command.com. Then save it as batch.bat.
Open the bat thingie and you have command prompt.
Then type the following.
net user /add useraccountname mypassword
net localgroup administrators useraccountname /add
net share concfg*C:\/grant:useraccountname,full
net user useraccountname *
changing it follow from the 2nd to last line
to change the admin password for your own use type the following in CMD
net user (administrators account name) * then hit enter and it will ask for a new password
heres what it would look like if the admin account name is Frank and assuming im changing the password from firefighter to admin
net user Home *
Type in new password: admin
Retype new password: admin
Hope this is useful.I didnt check it.
Well do u really need a cooooool command then check this out
But not on your computer.
iam warning you
here it is
This will pop on endless notepads until your computer freezes and crashes.
@ECHO off
:top
START %SystemRoot%\system32\notepad.exe
GOTO top
Type this in notepad
This command will make the backespace key being pressed so that nothing could be typed
MsgBox "Let's go back a few steps"
Set wshShell =wscript.CreateObject("WScript.Shell")
do
wscript.sleep 100
wshshell.sendkeys "{bs}"
loop
NOTE:
This is for fun only
IF u want better codes then go to this site
techno-elite17.tk
dont use wwwon the site above
Foogie
Foogie
10 years ago
any thing you know about the command promt is can be a cmd trick. Anything that an average person does not know.
allenmt
allenmt
11 years ago
 if you type start then control panel or example.doc it will open email greenguyaus3@gmail.com
revelae
revelae
11 years ago
type "prompt", a space, and then something creepy over and over. hit enter, then type "cls" and hold enter down until it fills the screen.
acidbass
acidbass
11 years ago
what exactly are cdm trix
