7418Views8Replies
can you turn your wirefeed welder into a plasma cutter.
can you turn your wirefeed welder into a plasma cutter. if you replace your gas line with an air line and connect the cables to the ,- terminals?
11 years ago
You might be able to. You'll need the air control and the feed hose and cables. Buy the cutting head that fits the cables.
You might have to adapt your connections also.
Be careful with the duty cycle.
Let me know how it comes out, I've got one that I would love to do the same thing to.
Answer 11 years ago
will let you know as soon as i get a chance to work on it
11 years ago
Unlikely without substantial electrical modifications. Plasma cutters usually use high-voltage, high-frequency to start ionizing the gas. Most wire-feed welders are DC only, except for the quite expensive models, and I don't think the frequency is high enough even in the AC models. There may be some way of making it work, but for the time, cost, and possible danger, it's probably best to just buy a plasma cutter.
Answer 11 years ago
i have the cables,hose and cutting head for a plasma cutter.
i thought i might be able to adapt it
thank u for your input
11 years ago
What kind of thickness were you thinking of cutting ?
Answer 11 years ago
body panels on cars
my son whats to change a few things on his car
11 years ago
Did you look at Youtube.com. There are some videos about homemade plasma cutters.
Answer 11 years ago
no i havent but i will be sortly
thank u for your replie
