3834Views6Replies
Author Options:
can you use regular electric guitar strings on an acoustic with a pickup? Answered
null
Tags:guitar
Little_Buster
Little_Buster
11 years ago
Only if its a steel string. If it a Nylon (classical) guitar, you may break the bridge as well as other stuff. -Buster
gmoon
gmoon
11 years ago
If it's a steel-string acoustic, yep. If it's a nylon-string classical guitar, no. They aren't designed for the tension of steel strings.
smcgrady
smcgrady
11 years ago
thanks for the info
NachoMahma
NachoMahma
11 years ago
. I've done it and it works well. . As a rule of thumb, electric strings are lighter gauge than acoustic strings and will have a "brighter" sound, but you can get "heavy" electric and "light" acoustic strings - a lot of overlap. Through the pickup, they will sound a little different than the same strings on an electric. With all the variations in strings of different styles/weights/manufacturers/&c, if you have to ask, it won't make any difference.
lemonie
lemonie
11 years ago
Similar to Xellers if you're using pickups you need steel strings, they're part of the pickup technology. The acoustic sound will be different, but acceptable.
L
Xellers
Xellers
11 years ago
I believe that you can. The pickup will still register the vibrations of the strings because they are still made out of metal, and the vibrations of the strings should also be good enough to take advantage of the guitar's acoustics. It will work.
