16702Views12Replies
Author Options:
charge a battery while using it? Answered
https://www.instructables.com/id/Ammo-box-speakers-2/
hi, i'm looking for a way to charge a 12v deep cycle lead acid battery while powering an amplifier from the battery. Can i literally just attach the battery charger to the battery as well as the amplifier as long as the connections to the amplifier and charger do not touch? or is it not that simple?
The instructable linked above is what i what to implement it into. Any help will be appreciated!
DamondamonA
DamondamonA
2 years ago
Hi guys I have this research thingy and I need to know is it okay to charge a 12v battery with a 12v DC motor and has a charge controller between while using it to power a 220v 50 watts electric fan with the use of an 12v - 220v car inverter?
I really need your advice Im just a novice here at electronics and all
iceng
iceng
7 years ago
Most battery chargers create electronic noise that will drive your amp sound crazy with
AC hum ripple and other amplifier induced electronic pops and thumps that could
damage expensive speakers..
A battery alone has the very smoothest DC power available ( that is wonderful for amps ! ).
YES .... If you can build a HiFi Power Supply that has voltage control
( not a simple charger ) then you could charge the battery at the same time as using it
to run your amplifier.
BUT .... That makes no real sense,  when you could run your amp directly
from that expensive HiFi Power Supply ! !
A
LucasS3
LucasS3
Reply 2 years ago
has anyone here thunk of using a electrolytic capacitor, to smooth out dem ripples.
iceng
iceng
Reply 2 years ago
Smoothing charger ripple with slow responding electrolytic capacitors will not work to rid amplifier charger spike noise..
It
will take a fast responding ceramic capacitors to trap little spike
noise and a series inductor in a Pi configuration to handle transient
disturbances.
WillERoberts
WillERoberts
Answer 7 years ago
could i just put a charge controller in between my battery and amp? or would that still allow electrical noise through?
My main reason for wanting to do this is so i do not have to disconnect the battery to charge it. With my current set up i can run the amp directly from the mains (with a 12v supply) while i disconnect the battery to charge it. But if i could remove the need for disconnection that would be all the better.
rickharris
rickharris
7 years ago
Quite a lot of articles have constant chargers attached with the battery acting as a buffer - The comments about noise should be heeded though.
If the supply is not large enough to drive the amp the current will come from the battery - in time the battery will go flat!
If the supply can drive the amp then the current will come from the supply. so you don't need the battery!
This system is only of use to avoid the necessity of re connecting the battery every time your finished.
WillERoberts
WillERoberts
Answer 7 years ago
iceng
iceng
Answer 7 years ago
Sorry there is no way to change reality just for your fervent desires.
This is the only way to use the battery ..... BUT IT WILL UPSET THE AMP.
WillERoberts
WillERoberts
Answer 7 years ago
what do you mean upset the amp? My amp can supposedly take upto 15v which is more than the charger gives so shouldn't it be fine?
iceng
iceng
Answer 7 years ago
I guess you should try it for your own experience.
A charger gives more then 15v ..... it gives RIPPLE.
The Ripple makes your amplifier believe it ( the Ripple )
is part of your signal and dutifully amplifies it.
Also if your starting with discharged battery ( it happens )
the ripple voltage dropping lower then turns off the balanced
input stage or puts it into a nonlinear gain then turns it back on
at 120 cps causing speaker braking Pops in addition to rumbling hum.
See the pics outlining this pulsing DC which is fine for a battery
BUT Horrible for amplifiers.
WillERoberts
WillERoberts
Answer 7 years ago
The charger I use is a cheap DC charger which gives a pretty constant 14.4v, so although there is some 'ripple' the current it is pretty consistant at 500mA.
I'll do what you suggest and try it for myself. It will probably be a couple of weeks before i try it but i'll post my findings here when i get back from holiday.
Thanks for your quick replies!
(if the ripple is too large could i just use a current controller between the amp and power supply?)
rickharris
rickharris
Answer 7 years ago
See ICENG's reply
ubdussamad
ubdussamad
7 years ago
No. you can't attach directly cause it will have bad affect the battery!
