50795Views22Replies
Author Options:
connect usb cable to usb keyboard Answered
I have a usb keyboard. somehow the usb cable is disconnected from the keyboard. I opened the keyboard. USB cable has 4 wires (1 blue, 1 orange, 1 white and 1 green). The circuit board has code like C, V, D and G. Now which one is for which wire? out of C,V,D and G which is for ground, which is for VCC and which is for Data+ and data- the color code of USB cable I know. But cannot understand which wire to connect which code (C,V,D,G) of circuit board?
sanchezas
sanchezas
8 months ago
Hi there, I have a question regarding the connection port inside the mouse. I have a dell. It shows d+(green wire), d-(white wire) , s(black wire), v(red wire), and g (empty no wire). I'm trying to add a timer to it and I need to add a wire to the v(red wire) and a wire to the ground, but my question is there is no wire that goes to the ground inside the mouse so where to I add my ground wire? In the empty slot? Or to the s(black wire) is it considered to be the ground? What does s(black wire) mean? Thank u for ur time
TarunVerma
TarunVerma
9 months ago
In my given mouse circuit below which wires are for power and which are for data here are four coloured wire white blue yellow and green
Abzalin
Abzalin
9 months ago
help me
how to connect zebronics keyboard wires with board of codes
C D G U+
rajashokr
rajashokr
9 months ago
i changed my ps2 to usb by usb cable,its power on but it does not working
hasewsew
hasewsew
10 months ago
Is S D- D+ G V and i have 4 wires 1 whit,1 green,red and yellow how can fix it ?
norbertofsouza
norbertofsouza
6 years ago
I found now the codes.
G - White 4 - Ground
C - Green 3 - D+
D - Blue 2 - D -
V - Orange 1 - + 5V
Or
G - Blue
C - Red
D - Green
V - Gold
Or Default
G - Black
C - Green
D - White
V - Red
That's It!
Any Error Blame Google!
LifeEndx
LifeEndx
Reply 1 year ago
anahtar kartımın D +, D -, G, V ve S harfleri var.
aryotob
aryotob
Answer 3 years ago
Thanks a lot, It's very helpful for my problem ... I can fix my cable mouse, and use it like usual ..
lexaRa
lexaRa
1 year ago
Hello guys I have the same problem but my circuit board has no letters on it. It only has the short remainings of the wires that have, from up to down, Green Black White and Red colors. I used a new usb cable and I have tried all of the possible combinations but it doesn't seem to work in either case. The new usb cable has the same wire colors as the board but those are only sorted like Black Green White Red. How can I fix it ? Thanks in advance and sorry for my bad english
LifeEndx
LifeEndx
1 year ago
D+
D-
G
V
S
Cables=Red,Green,Yellow,White How can i do?
Quincy13
Quincy13
2 years ago
Hi I have a havit wired keyboard & mouse & I don’t no where to put the other wires can someone help me please
CharlesE40
CharlesE40
4 years ago
guys my key board has letters of D , C , G , and U what wires do I put to those
DionS1
DionS1
5 years ago
I have a lot and here is most of them uses
G For Ground Wire Color Blue
C For Clock Wire Color Green
D for Data Wire Color White
V for VCC Wire Color Red
norbertofsouza
norbertofsouza
6 years ago
After All. Try using the Multimeter to find 4,3, 2,1 conections at the plug and it will
be easy to identify which is which.
zzxsw
zzxsw
9 years ago
i have the same colored wires in my ps/2 mouse i think white is d- and orange is d+
blue is vc and green is ground. I'm not sure if its the same in keyboard.
11010010110
11010010110
12 years ago
identify the vcc and earth somehow (find a big capacitor inside and look at its polarity and connections - near sure its vcc and earth. look at the num lock leds - sometimes they go with 1 side to vcc or earth. if there is a back layer inside the keyboard with just one conductive net all over it it usually is earth) now experiment with the 2 options of the data wires wire colors in usb cable are often not standard (many manufacturers just ignore the standards). use led and battery to find for sure which wire is who i guess that in the keyboard v and g are vcc and earth but dont just trust that
jpsarkar
jpsarkar
Answer 12 years ago
V mark line, one connection of capacitor, one connection of NUMs led and one connection of CAPS led are in a single line of circuit board. Means they are connected together. Other connection of that capacitor and G mark line are connection together. C and D mark lines are not connected to any other part of the circuit board and they are connected with central processing system (big black) of the circuit board separately.
frollard
frollard
Answer 12 years ago
either google the spec sheet on the processor in there, find which pin is which, or hook it up one way, if it works, yay, if not, then try the other way.
11010010110
11010010110
Answer 12 years ago
today most keyboards have the chip as a splash of black plastic right on the board and nothing written on it
11010010110
11010010110
Answer 12 years ago
then v g are power and c d are data does the capacitor have + - on it ? use it to know for sure you can see by the leds too. in most leds (there are some leds that dont follow this rule though - mostly red blue white) the big part inside is - and the stick is +. then the entire big shared line it goes to is - or + respectively otherwise lets just guess that v is vcc and g is earth
