103Views4Replies
Author Options:
continuity between 3.33v and gnd on atx psu? Answered
Im converting my atx into a bench psu. I was checking the continuity between 5v and gnd that i connected to the LTC3780 and i got a beep (one short beep). So i checked the rest of the lines and 5v and 12v also 1 short beep. However on the 3.3v. i get  a long continuous beep.
Is this behaviour to be expected?
thank you in advance.
LargeMouthBass
1 year ago
If continuity is only indicated briefly, it could be the result of capacitors on the output that initially behave as a short when the test leads are applied.
I would retest each on the ohm setting rather that just a continuity check. If there are capacitors on the output (which is very commonly the case for a power suppply) then you would observe an increasing resistance value, as your ohmmeter charges the capacitors. If there is an internal short, I would expect a low resistance reading to persist.
icey.hoodLargeMouthBass
Answer 1 year ago
Between gnd and 12v its rising 300+ ohm and 5v is steady at with a slight decrease between 51 and 49 ohms.. and 3v is 36 droping to 19 ohms. would this be a easy fix or shall i just get another atx if possible?
icengLargeMouthBass
Answer 1 year ago
+1
Understanding R C circuits is crucial to working with electronics.
Downunder35miceng
Answer 1 year ago
Not really....
Before I started to grow up enough to start work I mostly learned electronics the other way around.
If it did not smoke it meant I made progress LOL
