438Views1Replies
Author Options:
control multiple leds one switch? ? Answered
High guys
Im looking to have ten of these:
http://www.lowcostledlighting.co.uk/g4-capsule-lamps-/212-g4-12led-17watt-disk-lamp-warmwhite-30mm-5050smd.html
in one circuit with one power supply and two switches! switch 1 will be an on and off! when switch 1 is on only one led will be on at once! if switch 2 is pressed one led will turn off and the next one in the circuit will turn on and so on! how would i do this!
steveastrouk
steveastrouk
8 years ago
YOu could do it with logic, but the easiest way is to use an Arduino, and a shift register, or a dedicated serial -led driver, like the Allegro A6280, which would let you play clever with lamp brightness.
Steve
