2298Views3Replies
converting bluetooth headset to bluetooth vibrator. tbut when the headset is connected we cant talk with phone itself?
i want to convert BT headset to BT bracelet vibrator. the problem is when the headset is connected to phone we cant talk with phone itself? is there a way to talk with phone mic and speaker when BT headset is connected?
10 years ago
Not sure what your goals are with this. I wanted to share my music on my phone with someone wirelessly. What I did was use the "wired" headset jack on the phone and spliced in a seperate bluetooth transmistter. I had to make a splitter cable for the wired jack on my phone, which splits the audio output to two jacks. One jack was a three conductor regular stereo, while the other jack was the four conductor hybrib stereo and mic. The bluetooth transmitter was a "Scosche Universal Stereo Bluetooth Transmitter for MP3 Players" from Amazon. the audio jacks I got from Radio Shack. Hope this helps
11 years ago
Most things like this that allow you to connect an external mic. will automatically shut off the built-in speaker and mic. to prevent feedback and to eliminate having to have a mixer circuit.
11 years ago
That's standard behavior for bluetooth headset/handsfree mode. You can transfer the call back and forth between handset and headset, but you can't enable both at once using this profile. Your phone, and your headset, may or may not support another profile which runs them in parallel... but I haven't seen one.
