123Views3Replies
coreldraw x8 image?
Some of my cdr images were corrupted by unknown reason. I don't know an exact reason of corruption. But if someone knows the solution which could assist me, please say me about it. I got error - Error Reading CorelDraw file. How to repair cdr file?
Best Answer 4 years ago
One of the solutions that can help me is below, it is alternative
method, and another method might
be https://www.repairtoolbox.com/coreldrawrepair.html CorelDraw Repair
Toolbox, software is an appropriate way to get back .cdr files in solid state.
Corel makes a .BAK backup file that has the same name and is usually
located in the same folder as the original file, but can also be located in the
/Programs/Corel/Programs/Draw folder.
When a file is corrupted or otherwise damaged, find the .BAK file, open it, and
copy it (save as) over the original corrupted file.
4 years ago
Thanks for all for help, I hope i'll solve my issue.
4 years ago
Recover from a backup (if you have any!), failing that you could try the following recovery tool for Corel Drawl: https://www.oemailrecovery.com/coreldraw_recovery...
Keep
in mind that the success rate of these kind of recovery tools is
usually pretty low, but can be worth a go in times of desperation.
4 years ago
By not using this topic to post spam.
