110Views8Replies
dc motors
Hi: Can anyone tell me why my 24volt dc motor which I just got rebuilt will only work on 12 volts and immediatly overheats and stops with 24 volts? Thanks, Royal
12 years ago
You broke it? If you had somebody else rebuild it for you, they are probably the best people to answer your question.
Reply 12 years ago
That is why I am asking here, he says it works on 12 volt so should work on 24 volt. It's 25 years old and needed rewound presumably from age and heat.
Reply 12 years ago
Ah, "he" says it works on 12 volt so should work on 24 volt. Maybe this is the problem. If the motor was originally running @ 24V and now it doesn't then the shop hasn't rebuilt it correctly?
L
12 years ago
. The motor may have been rewound for 12V. . The motor leads may need to be configured for 24V operation.
Reply 12 years ago
Are you implying the lead wire to the commentator or brushes?I suspect he may have used a larger size wire on the rewind. Would that do it?
Reply 12 years ago
. Some motors will have multiple coils. When wired in parallel, they work at a lower voltage. In series for higher voltage. This may only apply to AC motors - I don't have much experience with DC motors.
12 years ago
Who rebuilt this and why? What sort of motor is it etc? L
Reply 12 years ago
A small motor shop. It runs a short duty hydraulic pump for cylinders. 15amp max no load.
