digital potentiometer pid?
hello, i have digital potintiometer u/d fgive you 100 step for 10k ohm so 10k for 100 step, i use it as outpu of pid control that read the distance and set point of required distance and make p and i and d equation based on differance and summation i want to use that pid to altitude contol of helicopter ,the resistor that i change as output is connected to throttle when i increase to max(5k) it stop and min 1k it go ?max speed so this work
code arduino
#include <DigiPotX9Cxxx.h>
#include <SoftwareSerial.h>
SoftwareSerial mySerial(52, 9,true); // RX, TX
int f=0;
char *buffer;
byte x;
char array[27];
int counter=0;
unsigned char r;
int p=0;
int last;
int error=0;
int wew;
int required ;
int kpipo;
int n;
DigiPot pot(22,3,24);
void setup() {
Serial.begin(9600);
mySerial.begin(9600);
void reading(){
mySerial.println(1);
while (mySerial.available())
x= mySerial.readBytes(buffer,1);
if(*buffer==0x52){
array[0]=*buffer;
array[1]=*buffer;
array[2]=*buffer;
delayMicroseconds(220);
void loop()
if (f==0){
delay(600);}
f=1;
reading();
int Final_inch=(array[0]-48)*100 + (array[1]-48)*10 +(array[2]-48) ;
float Final_cm=Final_inch*2.54;
Serial.print(Final_inch);
Serial.println(" Inch ");
//Serial.print(Final_cm);
//Serial.println(" cm ");
required =29;
error = required - Final_inch;
//Serial.print(error);
//Integral = Integral + Error; // accumulate the error integral
//else {
// Integral=0; // zero it if out of bounds
kpipo=1;
p = (error * kpipo); // calc proportional term
// I = //Integral*kI; // integral term
//int D = (Last-Actual)*.1; // derivative term
wew = (error/2) ;// scale Drive to be in the range 0-99
Serial.print(wew);//(wew)
if (abs(wew)>400){
wew=0;}
if ( wew >99) {
wew=99;
if (wew <-99) {
wew=-99;
n=abs(wew);
if (wew < 0){ // Check which direction to go.
pot.increase(n);
delay(500);
else { // depending on the sign of Error
pot.decrease(n);
delay(500);
last = Final_inch; // save current value for next time
7 years ago
You want to control height above the ground using
the Arduino PID control of a digital pot to adjust
The main rotor RPM ..... is that correct ?
How does the uP know how high the helicopter is ? ?
What is the feed-back for PID ( Proportional, Integral, Differential ) loop set point.
A
7 years ago
Use the Arduino PID library !
