111Views4Replies
Author Options:
diy shoulder axle/pin/shaft/dowel pin? Answered
I would like to
- create a shouldered pin* in order to glue gearwheels** to it
- ask you for any advice or link that may hint me towards a solution
any ideas are highly appreciated:
i already had a look at misumi, conrad, rscomponents, alibaba, ebay, amazon "small parts" …
but could not find any suitable solution.
* pin's dimensions:
                       left                   center                 right
diameter        1 mm             2.5 mm                1 mm
length            2 mm             13 mm                 2 mm
**made from delrin & brass.
These gearwheels are spinning at a speed of ca. 4000 rounds per minute
(a prototype*** worked well with superglued-gearwheels )
***my prototype: 1mm steel wire surrounded by heat-shrinked tube
mpilchfamily
mpilchfamily
5 years ago
Keep looking. You'll find a commercial option that meets your needs. Just a matter of finding the right search terms. Not all offerings are available online either. So it may be a good idea to call a supplier. Describe what you need and they may be able to point you in the right direction.
marc_is_curious
marc_is_curious
Answer 5 years ago
thanks a lot for your replies!
I started looking at the large companies thinking that they set the standards
but it might really be worth to look at the yellow pages/ local hardware stores since my project's measurements doesn't seem to fit the online offers.
rickharris
rickharris
5 years ago
I would have thought any local engineering firm could make you what you want for a reasonable cost.
