I disagree with what Flunker said. Maybe some people like to play that way, but it's up to you. Personally, even for 3v3, I like big fields with deep wooded areas, open areas, and light woods. For a bunker, it depends on what you want. Some people would use a shed with windows/gun slits around the side. If you want to make it yourself, try making an octagon out of wood and taking one of the sides out. Make it about 1-2 feet tall, and dig a 2 foot hole behind it. This will give you plenty of space to hide behind. You could also put two sticks in the ground about 2 inches away from each other. 2 feet away, do the same set up. Then stick some more sticks in the hole it creates. You now have a wall without any nails, ropes, etc.
I would check out some sites that have layouts of fields and go from there. Depending on how long you want the games to go, and how many people you have, the size of the field should vary. You don't want a 3 on 3 game on a huge field, i.e. 200 yds x 100 yds, otherwise the game will take forever.
As far as layouts go, try to make a big bunker in the middle, for this you can maybe find some old tires and build them up to make like an H design and then around the rest of the field, use the terrain to your advantage and create cool obstacles that provide some good angles to other bunkers you have placed.
One other comment, would be to keep the bunkers symmetrical so one team doesn't have an advantage over the other.
11 years ago
I have a 'how-to' that could be useful here, click me for it :D lol
11 years ago
11 years ago
I would check out some sites that have layouts of fields and go from there. Depending on how long you want the games to go, and how many people you have, the size of the field should vary. You don't want a 3 on 3 game on a huge field, i.e. 200 yds x 100 yds, otherwise the game will take forever. As far as layouts go, try to make a big bunker in the middle, for this you can maybe find some old tires and build them up to make like an H design and then around the rest of the field, use the terrain to your advantage and create cool obstacles that provide some good angles to other bunkers you have placed. One other comment, would be to keep the bunkers symmetrical so one team doesn't have an advantage over the other.
