1226Views6Replies
Author Options:
does anyone have any ideas on how to make a cracked concrete fountain/birdbath water proof again?.....? Answered
Dr.Bill
Dr.Bill
11 years ago
Hydraulic cement mix small amounts as it tends to set-up fast see home depot
paganwonder
paganwonder
11 years ago
Fill cracks, seal with appropriate epoxy paint (I like Sherwin- Williams for paint- my painting sub-contractors buy from them).
artist without a medium
Answer 11 years ago
I was wondering about a possible paint solution after seeing some huge terra cota pots that had a pretty blue glaze on the outside . Will have to research more since this is for a Antique concrete birdbath
Pkranger88
Pkranger88
11 years ago
http://www.lowes.com/lowes/lkn?action=productDetail&productId=137835-286-112611&lpage=none
If you don't like Lowe's, check out Home Depot or Whatever you have around. There should be someone selling concrete patching material.
Clean the crack well. Use some etching like muriatic acid or even a little less caustic, phosphoric acid, to clean the concrete and remove surface films.
A hairline crack may be sealed with 2 part epoxy, but the concrete sealant should bond well to the crack. Once clean, follow the directions on the sealant. To maintain a relatively smooth surface, use a putty knife.
Good Luck.
Answer 11 years ago
Thanks for info. This is for a Huge Antique concrete birdbath.
