172Views10Replies
Author Options:
does my circuit need any resistors? Is the capacitor needed ? Answered
steveastrouk
steveastrouk
3 years ago
Yes, Nice fat 100uF where the power enters your board, with a 100nF ceramic across that, also 100nF on the output of your voltage regulator
drystreams
drystreams
Answer 3 years ago
Thank you! I understand you suggest I put one on the input of the board and on the output of the voltage regulator. What does "with a 100nF ceramic across that" mean? Not being sarcastic but I want to make sure I understand what you mean. Thank you.
steveastrouk
steveastrouk
Answer 3 years ago
Put a 100 nF cap in parallel with the 100uF capacitor
drystreams
drystreams
Answer 3 years ago
Like this? Sorry I'm new to this.
drystreams
drystreams
3 years ago
mistake on diagram. how it really is
drystreams
drystreams
3 years ago
The blue wire is what triggers the relay from NO to NC. The regulator is an NTE960. I have not had any issues (running for 3 days) with not enough power or regulated power. I will incorporate. Made a mistake on the diagram. Here is how it really is...
iceng
iceng
3 years ago
By all means daystreams your ecoli incubator circuit aha is here
https://www.instructables.com/community/TE9RPH4JAV...
I do not understand the blue wire to the relay which needs a reactive diode across the coil.. Excluding the heater & relay, each component that uses power needs a filter cap 4.7uF tantalum or electrolytic and a 0.1uF disc or mylar as close as possible.. Especially both sides of the regulator..
rickharris
rickharris
3 years ago
More than likely.
Needs more polishing ICENG.
iceng
iceng
Answer 3 years ago
+1
This occurs when there is no corresponding image supplied daystreams.
