286Views14Replies
Author Options:
drain in kitchen not draining? Answered
had a guy snake kitchen drain and still did not drain until he took off the mechanical air vent, so he said to replace the vent, after replacing the vent there was no change, the drain is very slow with the vent on, if the vent is off it drains fast, I have tried 2 vents they are the black cheaper vents. any help would be appreciated.
Thanks
the sink is a double
Lotsa Bad Luck
Lotsa Bad Luck
7 years ago
I just thought of something. Try this: funnel a bunch of baking soda down the drain. Try to get it as deep as you can. Next, pour a lot of vinegar down the drain and quickly start plunging. The pressure, movement, end chemical action should work. If the sink has two or more drains, you'll probably have to do them all at the same time. Try this out and tell me if it works.
chunkeluvr53
chunkeluvr53
Answer 7 years ago
drain guy came out and cleared the drain monday a friend told me about the baking soda on tuesday.
Thanks for the help I will remember this in the future
mpilchfamily
mpilchfamily
7 years ago
What vent? The plumbing vent that goes all the way up to the roof? If so there may be a clog in the vent further up. A bird may have nested in the vent.
chunkeluvr53
chunkeluvr53
Answer 7 years ago
no it is small mechanical air vent under the sink about 6 inches above pipes there is no pipe going up to the roof
mpilchfamily
mpilchfamily
Answer 7 years ago
Do you still have problems if you keep the vent open?
chunkeluvr53
chunkeluvr53
Answer 7 years ago
it would not drain at all today until I used a plunger now it drains slowly
chunkeluvr53
chunkeluvr53
Answer 7 years ago
it would not drain at all. when I opened the vent water would come out of the top but would not drain
chunkeluvr53
chunkeluvr53
Answer 7 years ago
drain guy snaked drain and is now working, thanks for the help
RavensCraft
RavensCraft
7 years ago
Here 's a simple trick that works for me with clogged drains:
1. Block off any vents or drains (If you have a double sink).
2. Fill a plastic gallon milk jug with hot tap water (not hot enough to scald you).
This will make the plastic jug more pliable.
3. Quickly turn the plastic jug upside down and place the mouth of the
jug into the drain.
4. Push down hard and fast and steadily on the bottom of the jug.
This will cause the jug to collapse and shoot a high volume jet
of water down the drain to clear it. It's worked many times for me.
Note : The above procedure will work best if the drain pipe itself is
full of water , so the jet / pressure from the jug has something
(drain water) to push against and transfer force to the clogged area
Also try snaking the vent pipe . There may be partial vent pipe blockage.
rickharris
rickharris
7 years ago
1. Do not pour fat down the sink
2. Your pipes are clogged up - You need a fairly rigorous cleaning system that will clean the whole pipe out - this may well include chemical drain cleaners. - Personally I leave them over night to do their work.
gadget-man
gadget-man
7 years ago
I once had the same problem and I can almost guarantee you that the pipes are just clogged. You should try one of those plastic strip things that have a bunch of teeth on them you will be amazed.
Kiteman
Kiteman
7 years ago
Is it possible to add photos of the various parts?
Plumbing varies a surprising amount around the world, and it's not always obvious what folk mean.
chunkeluvr53
chunkeluvr53
7 years ago
if I loosen the vent it will drain fast but water will come out of the top of the pipe
tgferreira184
tgferreira184
7 years ago
Remove the sink pipes and give them a very good clean. Also, try the syphon, as it may be clogged.
