97Views2Replies
dsl is turn on and screen is also on for a second and then goes off ?if i open all the way it works fine.
my nintedo dsl lite is turn on and screen is also on for a second and then goes off . if I open it all the way it click and works fine then if i turn the screen little bit down it turn off.please let me know what i should do? I open the bottom of the nds but i scared to pull out the cable.? please explain me how to pull out that big cable
12 years ago
usually there is a part that slides into the connector together with the cable. it is often of different color and is a bit larger than the connector to release the cable pull it out (itll go 2 - 3 mm and then stop) and take out the cable to connect insert the cable untill it stops and then push in the extra part
Answer 12 years ago
I will be appreciate more if you explain little bit more detail I open the bottom part of nds i show one cable came out of hinges and connect to the mother board do I have to replace that cable how can I get the other end of that cable it looks like in the hinges. thanks foe your time and reply me.
