109Views11Replies
effecient charger making?
i wanna make a charger for 4v, 0.5A batery
1)just suggest me the value of capacitor and inductor for filter ckt
2) and wat ampere of current should be sent to battery for fast recharging (at safe zone
7 years ago
What kind of battery are you charging? This will determine what you need to effectively charge the battery.
What supply are you using to provide power?
Answer 7 years ago
lead acid
Answer 7 years ago
lead acid
Answer 7 years ago
iam using 230v,50 hz AC ,supply (and using 12 volt transformer to step down( is t trnsfrmr rating is sufficient for fast rechargin?
Answer 7 years ago
Ok back to my first question. What kind of battery are you trying to charge. Some batteries are very picky about how they are charged. Others only need a couple of extra volts running into them to charge.
7 years ago
What sort of battery:
LEad Acid (car battery)
Lithium
NiMh
Nicad
Dry cell (not recommended)
Alkaline call (not recommended)
NiFe cell (Yes they do exist)
Answer 7 years ago
lead acid
7 years ago
From what supply ?
Answer 7 years ago
sry its 230 v
Answer 7 years ago
You need a transformer. What kind of battery is it ?
Answer 7 years ago
2230 volt,50hz AC suply(steping down using 12 v transfmer,( is the rating f transfrmr is sufficint?
