electic generator
I have not made this yet, but my idea is building an electric generator using a bicycle wheel surrounded by a non turning metal frame. Tightly backed on the bicycle wheel would be permanent magnets arranged in a slant pointing in the same diection and outward toward the surrounding frame. On the frame would again be permanent magnets wrapped with copper wire slanting inward toward the bicycle wheel. The magnets facing each other would have like poles. North facing north or south facing south. I know this is just like an electric motor so far. You would get the electricity from the arrangement by placing a thin copper stip on the top of the frame. But different from the motor is the idea that like poles repel. once you gave the wheel a slight movement in the same direction that the magnets slant the wheel would turn until the magnetic energy would exhaust. You could make strong magnets using rebar wrapped in copper wire and use a inverter to change the AC in your house to DC and connect the current to the copper wire surrounding the rebar. Then when the magnetism of the rebar is sufficiently strong cut the rebar using a hack saw into small pieces to place in either the bicycle wheel or metal frame surrounding the wheel, I'm not sure of the electric power dynamics you could produce, but it would seem that using strong enough magnets could make a generator that could power as large a device with amperage/volts you can create. It might be used as a device to run your furnace blower or refrigerator in an emergency if the power produced was high enough. I think this would all depend on the strength of the magnets you produce. But if it works-you could have electric power from the magnets as an alternative to batteries or gas driven generators.
11 years ago
Skim down to section 4.
Reply 11 years ago
Why did you choose to keep this once-dead topic going? Until Sunday no one had touched it for 2.5 years.
L
Reply 11 years ago
Er, it was Lira, not me. She's switched to the same username and avatar...
>innocent whistle<
Reply 11 years ago
O_O
I just had that idea!
Reply 11 years ago
Tut tut, sort her out eh... L
11 years ago
or ignore the laws of physics and give it a shot anyway... i've heard that if you're going to make magnets from rebar in the way you're suggesting that it's best to have your tongue on the end of the rebar while you're charging it
11 years ago
Or look up "John R.R. Searle Generator" 1952, ignore the anti-gravity angle.
13 years ago
Look up "perpetual motion machine", "the first law of thermodynamics" and "conservation of energy" before starting this. Regards L
