424Views5Replies
electric shaver ideas?
i have an electric shaver but the battery recently burned out, any ideas for what i can do with it or the parts?
Best Answer 8 years ago
When the battery on my electric razor died, I removed the old batteries, plus all of the components comprising the charger circuit, and installed a 2xAA battery holder in the place of all that junk that used to be there. Then I wired this new battery supply through the old switch on the front. Also I cut a hole in the case, to facilitate pulling the two AA batteries in and out.
So basically the only remaining electrical components are: batteries, switch, motor, and that's a lot more simple than it was before.
The batteries it uses now are two nickel metal hydride (NiMH) AAs, and I charge these, when necessary, by way of an external charger.
Some pictures of this are attached.
Answer 8 years ago
I just noticed in the related panel, an instructable
https://www.instructables.com/id/Replace-a-Dead-Rechargeable-Battery-in-a-Shaver-o/
describing pretty much the same thing I did with my shaver; i.e. installing a 2xAA battery holder.
8 years ago
thanks everyone for your answeres, i appreciate your help
8 years ago
If you just want to re-purpose the parts, then open it up and remove the motor and the gear system. They can easily be re-used in another project. :)
8 years ago
You might be able to replace the battery. Many rechargeable things are now using standard size off the shelf batteries. It saves them a lot of development costs. So, take it apart and see if they are the same size as a normal double or triple A. If you can solder in a new one you should be good to go.
