Your Head Gasket failed, and your motor is totally borked now. When the gasket failed, coolant mixed with the oil and washed the lubrication off the Journals, bearings, cylinder walls,and any other critical moving parts needing continuous lubrication.Since you state you lost compression it sounds like a completely seized motor isn't to far away. You need to replace the motor,or a ground up rebuild or get a new car( very nice!) Good Luck Tragic
If it is a car then my first guess is a leaking head gasket. It can be a DIY job to replace one but it does take time and you need a good manual for all those little things that need to be done right.
9 years ago
in case the first 5 answers don't drive home the answer. I suggest head gasket.
9 years ago
Head-gasket. Have it replaced.
L
9 years ago
Have you lost compression on all cylinders ? = head gasket.
Using oil only = piston ring stuck or cracked.
Engine rebuild is in your future plans. Not THAT hard to do, if you have access to the people with the machine tools.
Steve
9 years ago
Head gasket
9 years ago
Good Luck
Tragic
9 years ago
I hope your talking about a car and not yourself.
