1817Views11Replies
free simple guideline for making hho generation cell?
can i make home made hho generation kit.if it is possible to make my own what is maint tips for it.
2 years ago
also an automobile alternator is constantly producing more voltage than necessary to operate vehicle. it has to be able to charge the battery, ignight the spark, run the headlights, turn signals, air conditioner, and whatever else may be running, the excess current is dumped or somehow cancelled, The belt driving the alternator is constantly running at engine rpm. anyway the extraneous energy that would normally be dumped can run the hho generator. and since hydrogen in its gaseous state is more flammable, you could probably reduce voltage necessary for the spark, or reduce the time of spark discharge. also saving current. the assumption of something for nothing has some built in errors, it assumes a vehicle is utilizing fuel current etc at 100% efficiency that's not even true with professional race vehicles, and your mom and pop sedan is way less efficient. its not producing something from nothing, as it is producing something that enhances efficiency. another thought, there are cars that run on alcohol, they don't produce the same level of power. why is it assumed that the molecular bond of water, requires the same amount of energy that is produced by the burning of the hydrogen? thats apples and oranges.....
2 years ago
H2O 1 hydrogen atom and 2 oxygen atoms, makes a molecule of water. running current thru water breaks the molecular bond freeing 2 hydrogen atoms and 1 oxygen atom, 3 oxygen atoms are consumed in the process. adding these free atoms to a mixture of gasoline and air, they have different characteristics that enhance and maximize the combustion process. a comparison you try to move a large heavy block, because of friction weight etc, it is almost impossible, add a lever, and now ith a large enough lever you can move the block, add a fulcrum and you multiply the value of your effort, Lever he block upwards and place a roller underneath, and given a perfect surface a child could move the same block. think of the gasses added as tools to maximize the potential energy in the gasoline. think about it, have you ever smelled unburned gasoline coming from a cars tail pipe? not all gasoline normally burns, enough does that it is worthwhile, but if you use tools to aid the combustion?
2 years ago
Gasoline is conveyed as clumps of molecules even in its finest state, it takes time to ignite and consume these molecules. one reason for spark advance is to compensate for lag between ignition and full combustion. (the piston in a car needs the thermal expansion to occur just after top dead center. so ignition before hand so thermal expansion is maximized.. now the incoming charge of fuel takes the same amount of time to burn whether you are putting along at say 1500 rpm, or racing at 5000 rpm. now hydrogen gas is just that, a gas it ignites much more rapidly, plus oxygen supports combustion, so if the presence of hydrogen and oxygen can accelerate the combustion sequence, there will be more relative time for complete combustion. also could possibly retard timing advance. (Because of speed of combustion.) so even if the energy of the hydrogen is a wash, the effect on the consumption of gasoline, (utilized more completely.) should be a benefit, the oxygen (greater percentage than atmosphere) is also an advantage. if advance can be retarded, and thermal expansion still occurs completely, there will be less time for the heat of combustion to soak into the engine and its cooling system. engine runs cooler. and since an internal combustion engine is a heat pump, anything that will increase the difference between intake temperature and exhaust temperature, should enhance power. as temperatures rise gasses expand tremendously, that expansion creates the power that drives the piston. another way to increase thermal rebound energy is via higher compression. there, the more you squeeze it, the greater the rebound. same goes for the cooler the intake relative to exhaust, the greater the rebound.
11 years ago
Firstly, it's not "HHO", it is "hydrogen and oxygen".
The process is called electrolysis, and there is no real secret - the more current you push through the water, the greater the amount of hydrogen and oxygen you produce. Anybody who claims they can produce a "better" kind of gas (HHO, "Brown's Gas" etc) is either mistaken or lying. Tricks like "applying frequencies" do nothing to the final product.
You need unreactive electrodes (platinum is good), or electrodes you can easily replace (such as carbon rods).
One big safety point - make sure you collect the gases from each electrode separately. If they are stored as a mixture, the risk of accidental ignition and explosion is huge. That means you must use DC current, not AC, otherwise you will have both gases produced in turn at each electrode, which consequently means the gases will be mixed and thus dangerous.
Answer 8 years ago
I am not saying that hydrogen wont explode in large amounts but the small amount of space where these gases pass through is not enough for a large explosion and any plans for hho generators usually have a pressure release valve, a water barrier or "bubbler",and a flashback arrestor as part of the plans.
I agree with you about the frequency seems like a waste of time to me
Answer 11 years ago
I believe HHO may just be referring to the ratio of two Hydrogen gas molecules to every one oxygen gas molecule. I also believe that frequencies may produce more gas with less electricity, but I could be wrong.
Answer 11 years ago
Those who use the term "HHO" seriously believe that the gas is somehow different to a normal mixture of hydrogen and oxygen. The frequency thing is also all wrong, as the amount of gas produced is directly and intimately linked to the amount of energy put in.
Answer 10 years ago
not, u are mistaken, some peoples try "anomalous frequencies" for do this eletrolisys. The correct frequency for use in a hho generator is the frequency of ressonance of the water, 2,45 GHz. And, if you are not satisfacted with this go make researches and study. Go study ressonance and you wil see.
Answer 10 years ago
If by "go make researches", you mean "google for it" I don't need to.
If you think it works, can you present a peer-reviewed reference, or just blogs?
11 years ago
. Even if one assumes that HHO is somehow "better" than H2 + O2, it is still a losing proposition - you can't get more energy out of a system than you put in. And due to losses from friction, radiation, &c, you can't break even. It's always a losing game.
Answer 10 years ago
yeah, if you could u are f****** the laws of phisycs. "In this house we obey the laws of thermodynamics" Dr Homer J. Simpson.
