77Views5Replies
Author Options:
frenchcrawler: can a insulated basic electromagnet be used to fish a metal object in a pipe in 8 feet of water? Answered
just want to know if this electromagnet  can be used under water
rickharris
8 years ago
Despite what you might think water isn't a very good electrical conductor. if you keep to 12 volts you should not have issues with the water anyway.
DON'T use mains power with water.
The Ideanator
8 years ago
Yea, but if you're really worried about shorts(or want to use it repeatedly) coat it in epoxy and you should be fine.
NachoMahma
8 years ago
.  Most electromagnets use enameled wire, which offers some short-term protection from water. It will probably not withstand repeated dunkings. For one-time use, just about any low-voltage (eg, 12VDC) coil should work.
.  If you want something that can be used more than once or if you will be using higher voltage (eg, 120VAC), get a potted coil and use wiring with water-resistant insulation.
Re-design
8 years ago
Yes. You must make the wires watertight so they don't short out though.
Re-designRe-design
Answer 8 years ago
An in the bargain it will pick up quite a bit more weight than it would on dry land.
