1614Views9Replies
Author Options:
heat shrink tubing on vacuum power cord? Answered
the insulation on my vacuum cleaner power cord has been stripped (due to the wheels running over it many times), I want to put heat shrink tubing over it,  how can i do that because the tubing does not fit over the plug on the end??
iceng
iceng
Best Answer 9 years ago
Wrap it with shrink tape and then shrink it.
I have ruined, repaired-many-gouges and replaced my cord.
Now, I have finally learned to pay attention to it :-)
A
Larry Breed
Larry Breed
9 years ago
Use a piece of Silicon Fusion Tape. You stretch it to activate it; then when you wrap it over itself it cures or "fuses" overnight, full cure 24 hrs.
embochner
embochner
Answer 9 years ago
thanks ill look into it
verence
verence
9 years ago
You could:
a) cut of the plug, fix the cable and install a new plug.
b) open the casing, unfix the cable inside the casing, fix it and remount everything.
c) same as b) but replace the cable with a new one.
I'd recommend option c) as a botched cable is a disaster waiting to happen. If the vacuum is one of the kind that stores the cable internally (on a spring loaded drum), the fixed cable might not be rolled up easily.
embochner
embochner
Answer 9 years ago
thanks for your answers--- id prefer not to cut the cable or the plug, if i open a peice of tubing and then put it around the cable and shrink it, will the srhink tubing stay?
embochner
embochner
9 years ago
Is there a difference between heat shrink tubing and heat shrink tape?
iceng
iceng
Answer 9 years ago
Yes,  No hole :-)
Both are irradiated materials that reduce their dimensions when heated.
But I used good old plastic electrical tape.
If you still hung on shrink tube,  take  verence's  option (b)..
