94Views4Replies
help ?
hi i have got trouble with my electric bike brushless motor.i have just brought from china 36 volt 700watt motor
it started to sound a bit rough.i have open the motor and there 6 wires glued.and 3 more wires just glued to a copper wire
can this be solded cheers
8 years ago
A
8 years ago
hi i just wanted to now if the wires could be solded in stead of glued cheers
Answer 8 years ago
If the wires look as though they are meant to have an electrical contact, then yes, soldering the joint will improve it. If not, they probably used glue for a reason. You can always unsolder them if you need to, so just start it up on low power and see what happens.
8 years ago
Some photos of the problem, or at least a part number would help people to give you some advice. If it sounds a bit rough while under power, it could be a fault in the driver circuit. If the problem persists while off-load or turning by hand, there could be an issue with one of the bearings.
Without seeing it, the only suggestion I can make about the actual wiring is that the wires may be to do with selecting the configuration of the motor, so don't need to be touched.
Also, you might want to add some more to the title so people know what you are asking.
