89Views4Replies
help me with ic's
I recently got some ic's from texas instruments and two of them came in bags that say: notice!! moisture sensitive parts. bake prior to vapor or ir soldering to reduce the chance of damage.What does this mean?
Best Answer 12 years ago
They probably don't want any water vapor building up near the chip. You should make sure the chips are stored in a humidity-free, warm place before soldering them. "Baking" them in a hot, dry oven may be what they're referring to, to get rid of any moisture before soldering.
Answer 12 years ago
thank you, but how would I go about "baking" them?
Answer 12 years ago
Are these surface mount ICs? I think the moisture thing might only be a problem if reflow soldering. If you're soldering by hand, it may not be a problem. This might be a generic warning message on all ICs, as it seems this is standard procedure with reflow soldering.
Answer 12 years ago
yes these are surface mount and i will be soldering by hand.
