77Views2Replies
help programming arduino
this is my code so far what i would like to do is connect a pir sensor,once activated there should be a delay of 2min then the two sevo's should be activated and run for 20 min then reset and only be able to reactivate pir after an hour
#include <Servo.h>
Servo vert;
Servo hor;
void setup() {
vert.attach(10);
hor.attach(11);
void migrate(Servo &myServo, int newPos) {
int wait=random(1,20); //randomize the wait to make it more interesting
int pos = myServo.read(); //Read the current servo position
if (pos < newPos) {
for (int i=pos; i < newPos; i++) {
myServo.write(i);
delay(wait);
} else {
for (int i=pos; i > newPos; i--) {
myServo.write(i);
delay(wait);
5 years ago
thnx mate will.give it a go
5 years ago
Something like this may help.
int timeCheck = 0;
int timeServo = 0;
Void Setup()
{//setup stuff// }
void loop() {
if(//pir sensor is activated//) {
timeCheck = millis();
while(millis() > timeCheck + 120000//two minutes//) {
timeServo = millis();
while(millis() < timeServo + 1200000) {
//do servo stuff//
if(millis() > timeServo + 1200000) {
//stop servo stuff//
//deactivated pir sensor//
timeCheck = 0;
timeServo = 0;
delay(3600000);
Obviously you have to write the actual code, but hopefully this format will help in some way.
