94Views3Replies
Author Options:
help with an ir remote? Answered
i need a remote with one button  that sends out any signal repetitively to trigger off this circuit
http://www.circuitlab.org/2011/11/circuit-ir-onoff-switch-using.html  thanks :) i need this to turn off a light or something like that
Re-design
Re-design
Best Answer 9 years ago
That remote receiver unit will memorize ANY ir signal you teach it. So any ir remote control unit can be used to trigger it. Did the unit not have instructions?
iknowvations
iknowvations
9 years ago
Every IR remote transmitter have special kind of patterns that are transmitted when any button is pressed. There are many standard patterns like RC5, SONY, NEC.
If you want to 'decode' this pattern you must use some kind of controller chip. Or else you can build some simple circuit that will accept output from IR sensor & toggle output every time it receives any IR signal.
techxpert
techxpert
9 years ago
i realise that the receiver will memorise any signal but i need a remote circuit to memorise first something that can be built simply with out any programming and if possible without a 8 pin chip although if it is only a pin thats fine. Thanks :)
