87Views5Replies
Author Options:
help with code Answered
hi , i have made a robot using arduino uno with aservo to move the ir sensor and two motors using l293....but i need a program for it ...
so please help me.....
Tags:irrobot
mpilchfamily
mpilchfamily
8 years ago
Check the Arduino forums. Also read through the tutorials on the Arduino main page to learn how to program.
kiran890
kiran890
Answer 8 years ago
actually i have tried that but i need a program
mpilchfamily
mpilchfamily
Answer 8 years ago
There are many projects posted on the Arduino forums that deal with the kinds of components you are working with. What you need to do is look at the code they use and get an understanding of how and why it works. Then you can either adapt the various bits of code you find or write your own from scratch. In the end if you want to play around with a micro controller you will have to learn to write the sketch/code/program to make it do things.
bwrussell
bwrussell
Answer 8 years ago
+1, also check out the learning section of Arduino.cc and you should be able to piece together some code from the examples. It's pretty easy to learn and isn't that so much better than having someone doing it for you?
steveastrouk
steveastrouk
8 years ago
Are there no ideas in all the links on the right of the page >>>>>>>>>>>>>>>>
