103Views2Replies
Author Options:
help with dyeing painter's canvas with diluted textile paint (before making a bag with it)? Answered
hi! bit of a noob here :) i'm planning to make a messenger bag out of some painter's canvas, and i would like to dye the canvas grey before i begin. i'm wary of using powdered dyes and stuff like that so i did a little research and found out that diluted textile paint would work nicely. what are your thoughts on this? and do you have any other tips regarding the process? (like, how to manage the shrinkage, what tools i should use, what things i should avoid, etc.) i don't really need it to look super slick or anything (i think it would look interesting if the dye job is uneven) and i might try and wax the canvas afterwards. thank you in advance for your input if you do reply :)
iceng
Best Answer 5 years ago
While you do not touch on temperature which I believe has a fixing property for inserting certain color chemicals into fibrous material and making it change to reduce its solubility thereby holding the dye in place.
Your research probably is far more extensive,
Best of luck :-)
iceng
5 years ago
Watching How-Do-They-Do-It they take raw silk thread and soak it in H2O2 Hydrogen-Per-Oxide to remove residual color Bleach the strands.
After that they dip the strands into a steaming Hot pot with the desired dye.
Then they hang the colored strands on a rack to dry.
