63Views2Replies
Author Options:
help with javascript? Answered
Hello, i just want to know how to change a variable's value permanently in a java script file using an input field. like i created a variable: Now the script displays you have 20 cars then i want to change that number-of-cars variable while staying on the page it means i want to modify the file and change the number of cars in that variable through an input box! Please help me with this!
Libahunt
Libahunt
Best Answer 6 years ago
Your description of the problem needs clarification.
What variable? Javascript variable? Or backend/database? Or HTML output?
For javascript variable could use onchange event of the input field http://www.w3schools.com/jsref/event_onchange.asp
That assigns a new value any time a character is typed into or deleted from the input box.
mh76dk
mh76dk
6 years ago
To change the size (lenght) of an input field you need to change the HTML (see:
http://www.w3schools.com/tags/att_input_size.asp ). Though it is possible to do with CSS (cascading style sheets) or dynamically with Javascript - The easy way if you are a beginner would be to set it in HTML - You can alsways do it in a different way when/if you get more comfortable with the languages you use.
And here is a discussion on how to get the value of the input field into a variable in javascript: http://stackoverflow.com/questions/3547035/javascr...
