507Views9Replies
Author Options:
high current adjustable power supply? Answered
i want to run my ps2 in car,
Any circuit to drop 12v to 8.5V at 6amps
the lm317 circuit is not powerful enough
iceng
iceng
7 years ago
As Steve said .... BTW when running your car puts out 13.5 volts !
The Power Loss math is analog voltage drop times current.
Power = 13.5v - 8.5v x current = 5v x 6amp = 30 WATTS of HEAT !!!
steveastrouk
steveastrouk
8 years ago
You're in Switcher territory, dropping 25 W is a lot to waste.
ARJOON
ARJOON
Answer 8 years ago
i came up with this on a datasheet
is it worth a try???
changing the transistor to achieve bigger current ?
steveastrouk
steveastrouk
Answer 8 years ago
It'll BURN with 25W of dissipation - the computer only takes 50.
Steve
Thuringen
Thuringen
Answer 7 years ago
No it wont. pass transistor/Regulator circuits at <10 amps float around 80% efficiency if the input voltage is selected properly. sure, switch-mode will be more efficient, but for cost, linear is hard to beat.
steveastrouk
steveastrouk
Answer 7 years ago
That's why reading the question is SO important
Any circuit to drop 12v to 8.5V at 6amps.
Which he illustrated with a linear circuit, and Lo ! it dissipates 21W, because THAT'S THE SPEC. He CAN'T select the input voltage. Yes, as a PE for the last 30 years, I am very aware of the benefits of linear regulators in the right places.
iceng
iceng
Answer 8 years ago
+1
We know, you know, a switcher is not a green wood sapling :-)
