107Views4Replies
Author Options:
how 150-300VAC 50-60Hz 0.15A adapter work on 110~120VDC? Answered
in India local trains are using DC to power up lights and fans inside the bogies.sum bogeys have power socket to charge mobile or laptops.but that socket is powered by  110~120VDC .is that possible. AC adapters can work DC
iceng
iceng
5 years ago
Most Apple chargers work on the Casmire affect, DC, AC, voltage, don't matter :-)
Josehf Murchison
Josehf Murchison
5 years ago
Chance is it will not work, the peak voltage at 150 AC converted to DC would be over 200 volts and way above 110 volts DC.
steveastrouk
steveastrouk
Answer 5 years ago
That's true, and may lead to overheating.
Downunder35m
Downunder35m
5 years ago
If I understand you correctly you want to know if a phone charge would work with DC input instead of AC?
Modern adapters use a step down converter.
The first stage is a rectifier to get a DC voltage - which is then changed to high frequency AC voltage to be transformed down.
So they don't really care if you feed them DC instead of AC as long as the voltage is within the operating specs.
Conventional transformers won't work as they really need a AC input.
