Where do you go to school ? I think you want us to design this for you. A 555 is a timer, oscillator, one-shot, modulator, candle-steady-flicker. An ldr is a photo-sensitive-resistor capable of small changes to flickering the candle rate as ambient light changes and a tripping point for a break-over semiconductor. You could use one 555 and the ldr to cause a pulse to occur. That pulse fires the second 555 to ( Turn ON ) light your LED candle and after a time out ( turn Off ). A 556 is a double 555. This design uses the battery all the time, you need a switch and if you have a power switch why all this. Use a tiny micro instead and get a few days out of a battery. Good luck,
9 years ago
Good luck,
A
