14474Views12Replies
Author Options:
how can I lower a fence post? Answered
on of our wooden fence posts has raised over the years. anybody know how to lower it?
Tags:fence
canucksgirl
canucksgirl
Best Answer 8 years ago
Unfortunately, you can't just lower it. It sounds like the post hole wasn't dug deep enough and below the frost line. As the temperature drops over the winter, the ground freezes, and all the water in it expands and pushes against things like fence posts. To fix the problem, you'll need to dig out the fence post, and make the hole deeper. You can check with someone in your area if you don't know how deep the frost line is in your region; or take HALF the height of your fence (above ground), and dig a hole that deep for your fence post (So a 6 foot fence should have 3 Feet of post in the ground). You should line the base of the hole with a few inches of gravel (which keeps water away from the bottom of the post), and then add the post, ensure that its level and plumb and add your concrete. You'll need to brace the post until the concrete sets, but thats about all you need to do.
Vyger
Vyger
8 years ago
Chain saw, small electric one will work.
reciprocating saw like a saws all.
Hand saw if you have the time.
Just cut it down to size.
frollard
frollard
8 years ago
Is the post set into concrete or just the ground?
If just the ground then disconnect the fence from the post (barbed wire/boards) -- then use a pile driver to ...pile drive it back into the ground.
helps to have heavy equipment or the like to really give it a good smack - because by hand it's gonna be a tough job. The reason it's heaving out is probably freeze-thaw cycle -- set it deeper to begin with so that frozen ground doesn't get under the bottom of the post.
Alternately, remove the post, make the hole bigger, and cement it in (also preferably deeper)...
DistantOverture
DistantOverture
Answer 8 years ago
it is a normal wooden fence. the posts are hammered into the ground
Koosie
Koosie
8 years ago
Grab a sledgehammer and teach it some manners!
(Also a great workout... :-) )
Jayefuu
Jayefuu
8 years ago
Cut the top off? :D
iceng
iceng
8 years ago
YES you can fix it but what about next year.
Winter freezes the the ground moisture under the fence post pushing it up
because of expansion.  Some winters cause a daily thawing and freezing
of the ground and bring up rocks ( literary grow them ) each year.
Why this post ?
Some how water is pooling around and under the post..
Provide a drain away path, pack dirt up higher around the post,
keep water away.
Inject a heavier ( denser ) then water compound around the post
keeps the water from slinking in when it rains.
A
kelseymh
kelseymh
Answer 8 years ago
In English, the term used is "frost heave."
It most commonly affects soil directly, leading to circular or polygonal structures in flat landscapes, but can also lift relatively large rocks out of partial burial.
mpilchfamily
mpilchfamily
8 years ago
Has it raised or has the ground eroded/sunk around it? If the post is cemented in place i doubt that it has raised. Most likely the ground has sunk or eroded away over the years.
Assuming this is a typical wood slat fence and not just some posts with a couple of post jointed between them. You can either take the fence apart and build it back to where it needs to be and cut the top of the post off, or you can build an addition to the bottom of the fence to fill the gap.
